09 230 Atlantic freshwater system
![ruffrider](https://w8.vanillicon.com/85ba3e495d77c552179d7adce9280664_100.png)
Does anyone know where to get the plumbing schematic for the Atlantic 230....I just purchased the boat and for some reason there are 2 Jabsco pumps....one operating from the dash switch and controling water flow to the sink....the other pump operates from one of the accessory switches..and when turned on, pumps water back through through the "municipal" water inlet....im not sure if the previous owner installed or made changes to this second pump...
Otherwise give me more information:
- are both pumps being fed from the fresh water tank?
- does the municipal water connection tee into the pump discharge? If so, is there a check-valve (non-return) valve on the municipal water line, and is it working?
- where does the pump that links to the municipal water line eventually pump to? After the pump discharge and municipal water line connect together, that pump should pressurize a circuit. If not, are you saying the pump only discharges to that municipal water connection? If so, it sounds like he may have used that pump to pressurize that point, so that he could attach a spray hose to wash the boat, or flush systems.
Mark
i have another issue now with the galley pump....I filled the tank and the pump runs, but doesnt want to pressurize the system....are these pumps self priming?
thanks everyone...i found an old link saying to run water into tank with taps...on...counterintuitive but it worked....must have been an air lock...
