246BR - Removing upholstery panel to replace LED light
DZ
Member Posts: 55 ✭✭
I'm stumped on how to get this upholstery panel, on the port side next to the captain's chair, just aft of the head door, off, so I can replace the dead LED below it. There are two screws inside the cubby hole, and if you take out one of the cup holders in the the side panel, you can get to a nut and remove it from a bolt sticking out of the panel. With those three off, it's loose at the bottom but still won't come off. I thought maybe just those held it in place and you pull up on it once they're removed, but that didn't work. Have a dead LED on a similar panel on the starboard side too.
Mark
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
