BATTERY SWITCH
minnesota
Member Posts: 67 ✭✭
Please help, Rinker techies . We just purchased a 2008 280. Loving the boat but I believe there is a wiring problem. The boat has
Battery switch= Blue Sea E-Series Circuit Plus. 3 positions "OFF", "ON", "COMBINE"
3 batteries, 2 in parallel.
When the battery switch is at the ON position; even with ignition in ACCESSORIES position: no radio, no horn, no accessories, no CO detector, no power to anything
When the battery is at COMBINE: everything works fine.
Obviously, I don't like to run the boat on COMBINE. Please help, what's wrong here. Can I remove the panel from the aft-port side to rewire? working at the back of the panel is not an option (no room).
Thanks
All breakers are good.
