Reverse Polarity issue
When plugging in this spring to my regular outlet on shore, the green light showing correct polarity is on . When turning on 110 breakers the reverse red light comes on . The stove is the only exception . All was fine last fall but had two dead batteries this spring ,one house and port engine , not sure if that connected. Replaced both batteries not same result. Disconnected live wire to charger with no change .
Any suggestions would be appreciated
I can get a picture of the breaker panel but not sure how to post on this site
Thanks
No ,But I will check right now
Thanks
FOUND THE PROBLEM !!!
started at the source. checked the connectors and found the connector at the shore power connection not making good contact --easy fix
thanks
