How to leave the boat?
Good Morning,
We just took delivery of an 04 342. We were supposed to have a captain join us for the 8 hour journey to our home port however weather in the Atlantic is not cooperating.
Can someone tell me what all steps I need to take to button up the boat before I leave for the week? I am in a slip with power and water.
Sorry for the rookie question but I am concerned about seacocks, how to leave the a/c etc...
Thank you in advance.
Leave your AC power on and your battery charger on. The Mercathode system will drain your batteries and leave your drives exposed to corrosion.
I personally leave my A/C on. Other than that, close up all your hatches.
If you have stuff in your frigs, leave them powered on too.
Personally, I wouldn't leave the hose connected at all to the boat (they can sink a boat if turned on). As far as switches, I only leave all battery chargers, fridges/ice maker. All DC switches should be off (toilet and fresh water). You should be plugged into shorepower, so the main power switches would be on.
Seacocks, well, most people leave them open. I keep my boat on a lift, so not as much concern (I do close A/C seacock so I don't lose prime).
Make sure your bilge pumps will kick on both manually and with the float switch.
In the cockpit, make sure your VHF radio is off and all windows are zipped (or the cockpit cover, if you're using that instead of the camper canvas).
