Acc Switches
would anyone know what these acc switches might operate or be wired to operate?
so far not found anything that they control
    One should be prewired for the swim light, one for a washdown pump and one is a spare just wired to the switch. If you get the wiring diagram from Rinker, it shows where they are prewired to and the colors of the wires at their terminus.
  • redlightningredlightning Posts: 284 ✭✭✭
    thanks.
    I found a switch in the left bank of switches that has one labeled swim light.  I also found the wire and connector in the motor compartment.  metered the wire and it works great.  going to add some led lighting at some point.
    would this maybe be the one you were referring to?
    what is a washdown pump?  I guess that would be located in the motor compartment?
    this is the wiring diagram I received.  a lot of good info but for my boat definitely some stuff left out.
    That is the engine wiring diagram. If you email Cindy Scott, she should be able to give you the boat wiring diagram. It is very helpful and shows you each of the circuits and what the wire colors are. The washdown pump brings in sea water to wash the cockpit area out. That is great that you have the swim light, which gives you 3 ACC switches.
