Dragging and squeaking
69fastback69fastback Member Posts: 951 ✭✭✭
I took my '03 Captiva 232 out for the 4th time this year, and had a little issue. It's a 350 Mag/Bravo 3, and I had both batteries fully charged before going. When I went to start the boat, the starter was dragging badly, and there was a very loud squeaking while the engine was turning over, and not starting. The engine eventually started, and continued squeaking for 5-10 seconds, and sounded similar to a belt squeaking, although I'm not sure the belt can squeak while the engine is cranking and not running?
I shut the engine off, and restarted it 7-8 times with no issue throughout the day. No dragging, and no squeaking......100% normal. Then, out of nowhere, it did it again. The starter was dragging, there was squeaking, and it didn't want to start. Once it finally did star, it was fine, and started normally for the rest of the day.
Thoughts?
    The serpentine belt moves with the engine, and when cranking the starter the entire rotating assembly is moving, so yes the belt moves. It could a belt tensioner or pulley on an accesory is providing too much resistance, causing the belt to slip and squeal. Or the belt is worn and not providing the proper friction. I'd start with a new belt and see if it helps.
    2013 276 Cuddy ~ 350 MAG / B3
    Check your idler pulleys too, bearings can go bad.
    Yeah, I have a slight noise that is coming from what I believe is a bearing.  Just trying to figure out which pulley is causing the noise.
    short shots of silicone spray will allow you to identify an isolate a bad pulley quick like.
    I'd say a bearing in a pulley is a good place to start. If it were starting to try and seize up, it would make it harder to turn, which could make the starter struggle to turn the engine over.
    Bad bearings in the alternator and water pump too, less likely in the power steering pump.
