Replacement fuel tank level sensors
LaRea
Member, Moderator Posts: 8,053 mod
If anybody has replaced or upgraded their fuel tank level sensors, what sensors did you use?
I'm on a long-term quest to upgrade my boat's instrumentation. I already have access to the Smartcraft engine data via two MercMonitors, so I can see my fuel burn rates. If I had tank level sensors on my network, the system could compute my range (miles to empty). That would be very handy to have.
However, my existing tank sensors aren't linked into the SmartCraft engine network. And even if they were, they apparently only read to the nearest 1/8 of a tank. That means my estimate of remaining fuel could be wrong by as much as 30 gallons at any given time. For example, if I'm down to 35 gallons of fuel and the gauges are still telling me 60, that's very misleading. Eventually, I want better tank sensors that connect directly to the engine harness and give me true analog measurements of the fuel levels.
Now, do I really *need* better tank sensors? Well, no. I guess I could invent a scenario where better sensors would contribute to safety, but really I just like having lots of toys to play with.
Stodge -- On my boat, it's all standard Faria analog gauges, no SmartCraft.
what part no did you use for the 4 in 1 gauge replacement
I have the smartcraft speedo and tach units in my 186br and fuel is connected but the faria 4 in 1 not does not work (fuel only everything else works) so would love to swap it out for a smartcraft 4 in 1
part no would be great need it in white with chrome bezel
thanks I am located down under in Australia
thanks for you assistance
Larry Kelly
Download this pdf.
http://mercurymarine.co.za/files/brochures/8m0063378_2012gaugectlg_lr2_0.pdf
See page 6 has all the add on gauges (SC100 series). Look for the 4 in 1. I believe it comes standard with a black bezel, so down at the bottom you can order other colors including chrome to match your other gauges.
exactly what I was looking for
cheers
larry
