93' Fiesta Veee 260 shower drain water problem - hull/drainage - diagram anyone? 260 owners?
I have a 93 260 FV - and I seem to be getting some water on the floor outside the step. The bilge (mid and rear) are empty.
I took up the carpet and strip underbathroom door and see a tiny bit of water SEEPING through the fiberglass onto the floor - I can't tell if this is comming through exterior hull, as it appears to be comming from a channel under the shower.
Speaking of shower, should i ever need to replace drain, I have no idea how one could ever access this again, the shower is all one peice with no access to back/bottom of drain.
I took out the water box in the head, which lets me see very little about the hull design. Under the step doesnt show much either.
I did see behind the box what appears to be another channel in the bottom hull (runs same direction as bilge) that was holding a little water - i'm shocked this doesn't drain into the midship bilge, and I can't locate any drainage holes...
I saw a similar thread on this but with no anwsers. Its not related to shower water - I did find a small drip in the cold water line which i fixed, but i'm concerned I saw water seeping through fiberglass, in what appears to be a small defect.
My concern why doesnt the channel under the shoer drain to the bilge... and does anyone with this boat have tips for getting to the showe drain and to that channel to drain it out??
