Windlass Installation on 2013 276CC
AdmiralWG
Member Posts: 12 ✭
Looking at installing a windlass on my 276CC. It is not prewired for a windlass but have been told that it can be done? Can you confirm that it is doable and what is involved? ie changes to the bow to accommodate this? Looking at a Lewmar V700 or equivalent. There is an anchor storage compartment and a bow ladder.
Best Answers
howardrams
Member Posts: 223 ✭✭✭
Rinker used a Quick Mini Genius 150W on my 260 and it works OK. You drill 5 1/2" holes in the floor of your locker on the bow, 4 for the bolts and one for the wires. There needs to be about a 2" hole cut with a hole saw for the chaiin and rope to go through. The instructions come with a template to eliminate guess work. Wires need to be fed through back to the helm for your switch and the switch needs to be mounted at the helm. There are options like foot pedal controls on the bow or remote controls which would add to the job if you like.
And make sure the end of your anchor line is bolted down usually to the bow eye U bolt inside the compartment behind your mirror. If you have skill and tools and enjoy little projects, have at it! -
raybo3
Administrator Posts: 5,588 admin
Why not put her at the helm and you do the anchor? Makes her happy and a lot cheaper.....lol2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Just make sure no arguments before she sends you out there. A quick shot in reverse will see you in the water!
