(another) Water in Bilge Concern...
jklein
Member Posts: 49 ✭✭
Hi All.
I would like to thank everyone for the feedback provided and previous discussions around "water in the bilge". I promise, I've read all the discussions...
I have a 2006 250 EC
its covered with the full canvas top all the time when not in use.
I beleive my bilge pump is working properly because in the past its gone on when blown the exhaust manifold and another time a hose clamp. It also works manually with the helm switch.
A few days ago I checked with the manual switch and pumped about a gallon out. Surprised that the float switch didn't activate (concern 1).
i decided to use a pump (all I had was an oil change hand pump) to drain the bilge dry. I was SHOCKED to hand pump out 5 times - I filled the oil pump tank (about 4 quarts) so almost 20 quarts of water... (Concern 2).
- why so much water in my bilge
- why so much water until the bilge pump comes on
so far I still have a dry bilge 48 hours of sitting at the dock. No rain or wash down since... I also haven't seen any engine/holding tank water leaks?
As for the amount of water, it only takes about 1 inch of water to generate 6 - 8 gallons of water due to the size of the compartment (about 3ft wide x 4 ft long). Measure it yourself.
