NEMA2K Issue
jhortajhorta Member Posts: 90 ✭✭
This last fall I added a new Chartplotter (741XS) and Fusion NEMA2K head unit in the cabin.  Up until now, the fusion and the Mercury Nema Gateway were the only 2 items hooked into the backbone.  Just this past week, I installed the Lenco Autoglide unit to the gateway as well.  For reasons unknown to me, the autoglide will not turn on unless the fusion head unit is on.  Any thoughts?  I assumed I just needed to tie to the backbone and be done with it.
  • LaReaLaRea Member, Moderator Posts: 8,041 mod
    Sounds like the Autoglide is receiving power only from the N2K network, and the Fusion is the only thing powering the network.  Could the Autoglide have a power lead that didn't get connected, or a fuse missing/blown?
  • jhortajhorta Member Posts: 90 ✭✭
    Good call, thanks!! Ill check to make sure the power is in secure!!
    Just saw just saw this post from a while ago. Did you get the autoglide to work? How do you like it? Was it a simple install? From what Lenco says, it’s plug and play if you already have the basic lenco setup. Was curious if it’s an easy setup?
