lots of play on steering wheel on a 212 Captiva
pjb155
Member Posts: 10 ✭
Hi all,
i'm new to this forum having just recently bought a 1998/9 rinker 212 captiva bowrider in Belgium (Europe) with a 350 mercruiser (250hp). i don't know the type of sterndrive, probably alpha one. This boat is quite uncommon in western europe.
I didn't notice this during the test run (so it may be a new problem), but now there is about 90 degrees play (!) on the steering wheel, making it very difficult to go in a straight line at slow speed. I understand a bit of play is normal, but this is really massive and somewhat dangerous.
The connection between the steering wheel and the "actuator" behind the engine seems to be ok, as the steering wheel and the steering wheel shaft have no play in it. With even a small movement of the steering wheel i can see movement at the back of the boat. However when i look at the actuator when someone is moving the steering wheel, it seems like the actuator is moving "within" the bracket first before really pushing/pulling on the rudder. I'm not so familiar with boating mechanics so i don't even now whether this is cable or hydraulic. From the hoses attaching to the actuator i would guess this is a hydraulic system.
2 pics are below of the actuator which connects to the sterndrive rudder. the shiny piston behind it seems to be a shock absorber and is not powered (i think).
Any help or ideas would be greatly appreciated.
many thanks
pj
many thanks
pj
Post edited by pjb155 on
if i understand correctly: the cables go from steering to the control valve behind the engine. this moves the hydraulic ram (shiny part in my pictures) which powers the rudder movement.
I guess this will take the same kind of oil as a car hydraulic power steering system.
thanks for your comments.
https://www.youtube.com/watch?v=lMqme9xhNGE
http://www.seastarsolutions.com/products/mechanical-steering/hps-rack-pinion-steering/
The remainder is in the cable system itself, so it will be a replacement after all to get it sorted as good as it can get with this type of hull
