MB Quart Auxillary Input
JBobJBob Member Posts: 7
Has anyone had trouble with the Aux Input on 2011 shorting occasionally to only provide sound to one side of the boat?  What were the causes and fixes?
  • MarkBMarkB Member Posts: 3,993 ✭✭✭✭✭
    I haven't used it, but I've seen the wiring. That auxillary plug in is connected to a female to female auxiliary plug, and the ausillaries from the radio plug into this. The connection is under the switch panel. Unscrew 6 screws and lift and you will find this connection right under the plug in.  It sounds like one of your connectors are grounding out, or not plugged in at all.
