windlass tension bar not grabbing?
i have an '06 250 ec and the windlass doesn't seem to want to pull up the anchor. while my nephew worked the button, i pushed on the tension bar and it pulled it up. it will grab the chain and hold the anchor tight once in position, but doesn't want to pull on the rope. can i rewind the existing spring? is there a replacement spring? i have not taken it apart yet but i do see what seems to be a spring set screw on the bottom of the bar. thanks
Item # : 001662
Control Arm Replacement Kit for V2 and V3 Windlasses
Includes Control Arm, Control Arm Pivot and Torsion Spring
Also Includes Hex Key, Service Grease and Washer
Brand: Lewmar
Model Number: 66810030
Our Price: $61.45
Handy, the rope is actually pretty solid. It's really dirty from about 3" of muck and dirt that was in the bottom of the rope locker. With that said, There is only 100' of rope and I am probably upgrading to a 150'. Is it normal to have 30' of chain? I was amazed at how much chain came out.
