BBQ for a Rinker 250
Hi Guys,
Does anyone with a rinker 250 have a BBQ mounted on the boat? If so where and do you have a picture? I am thinking about a Jackson versa 75. Has onyone used this model? What do you recommend as a reliable bbq.
Thanks in advance
Thanks in advance
http://www.downwindmarine.com/Magma-Fish-Rod-Holder-Mount-for-Marine-Kettle-Grills-p-91000586.html
Spot 1 - on starboard rub rail. Great spot if you can cook right off the dock. While we are underway, this is the spot I normally stow the grill. It does not get wet, and is very well protected there.
Spot 2 - mounted on one of my scotty rod holder bases. Great spot if you are on the water. The scotty rod holder is very easy to install. 4 screws or if you can get under the gunwale, through bolts.
