It looks like you're new here. Sign in or register to get started.
Here's what I received from someone that's worked with Rinker: The engine will need to be removed to get the tank out through the engine hatch.
The firewall will need cut out for access along with the aft cabin floor.
Once you have access to the tank, the fiberglass straps holding the tank will need cut so it can be moved back and out through the engine area.
This make sense? Thanks, Greg
