Transom Door hinge on the bulkhead side
I have a 2005 FV 250. it seems the bolts holding the top hinge of the transom door on the sidewall is stripping out. Probably because my rite of passage of leaving the door closed while raising the engine hatch once too many times!
If I unscrew the bolts, it seems the nut on the other side is unfastened and will drop into the sidewall. If it is that, and it drops, it seems it would be irretrievable and I probably will have to use a different fastener for the door hinges altogether. Any experience ones out there with this issue or recommended fix?
I have some "door, hinge and bolt" experience with my 342. If I remember correctly with the 342, the screws are threaded right into the fiberglass. One of them turns and no longer tightens, but the others still do. When I get the boat back to home dock and can work on it/use it once again, I plan to insert a wooden toothpick into the hole with the stripped threads that would serve as a 'threadable shim" and see if that idea could fix my problem.
Yours must be a bit different, using nuts on the backside that are inaccessible. The toothpick idea might work. And at Lowes hardware area, I think they have an assortment of blind type fasteners some of which are quite clever, many intended for drywall, one of which might provide a solution.
Anyway, good luck with this and let us know what you come up with.
Tony
Salt Shaker 342
Good input MT.
