Ignition interrupt and 2 beeps
pinevuepinevue Member Posts: 9 ✭✭
edited July 2015 in Engine Discussions
I Have an 05 270 FV with a VP 8.1 and I'm puzzled.....as I get in the 3500 RPM range I get a momentary ignition interrupt and 2 beeps, it now has become fairly persistent.  I changed the fuel filter, that didn't help.  What really puzzles me now is I have also discovered that moving the trim button, either up or down will also cause the same interrupt. i have switched batteries, no change.
Thanks for any advice.
    edited July 2015
    Could be trim switch.  I believe in the library there is a list of faults for the 2 beep faults.  take a look there.
    Oh, and welcome to the forum!
  • pinevuepinevue Member Posts: 9 ✭✭
    Resolved, found the positive cable to the starter solenoid loose, half a turn and back in business.  Did find some corrosion starting on wires to the trim switch and the ignition switch, going to get some spray and tend to those also.
