Shore power - burn/charring
buggyjdavbuggyjdav Member Posts: 134 ✭✭
I have an 04 342, the shore power cordset is charting at the boat side. Thinking of replacing cords and outlets on the boat. Would cleaning and using electronic lubricant be a first step or just replace?
  • LaReaLaRea Member, Moderator Posts: 8,022 mod
    When this happened on my 342, I decided not to take any chances, and I just replaced the cords and receptacles.  I figured they could have heat damage that's not visible and/or not affected by cleaning the contacts.
    Also, I forced myself into the habit of turning off the breaker before disconnecting, and not turning it back on until after I was reconnected.  That keeps the new receptacles and cords from getting burned up.
  • l-skynyrdl-skynyrd Member Posts: 178 ✭✭✭
    This also happened to me a couple years ago. I bought new  Y cord and receptacle.
    Also do the same as LaRea with the breakers. No problems since.
    Len
  • buggyjdavbuggyjdav Member Posts: 134 ✭✭
    Thank you both, New cordset and outlets on order
    The outlets are easy to swap out. Make sure the gasket goes on right or it will leak.
  • raybo3raybo3 Administrator Posts: 5,592 admin
    Had the same problem. Replace the receptacles on the boat and found the wires on them were loose. Loose connections cause heat and burning.
