engine just stopped on 2007 Captiva 192
dtfreedtfree Member Posts: 1
I was driving full throttle down the lake and all the sudden the engine just stopped.I shut everything off, turned the ignition back on and there was no power at the ignition switch. The blower, horn, nav lights, and power trim all work. the boat has gas. I checked the kill switch and all fuses, so far no solution. Any ideas?
  • aero3113aero3113 Member Posts: 9,712 ✭✭✭✭✭
    Check the main harness plug at the engine,maybe it backed out? There is a red main breaker that you can check back there also.
    Check your coil and coil-to-dizzy wire... That particular plug wire sees 4/6/8 times the use of the others, so it gives up the ghost first.... If it needs replacing, it's a good indicator all of them do... The filament usually kicks out the ghost where it bends, which is either end of that wire and right behind either boot.
