Key stock in the ignition...has it ever happen to anyone
sansteph
Member Posts: 34 ✭✭
just had a weird thing happen...turned on the motor...however the throttle was in forward...the motor started when put back in netural but then key went a bit further and it s now stock...can remove it from the ignition...(it s in on mode). Any idea. Or suggestions?
thks
thks
Marvel
one thing i have noticed is when i put the other key on the on (position) it beep twice(which it always did before i start the motor) but there is a small light sound (high pitched) that keeps going even after the motor is started...i am quite sure it was not doing this before. I think you showed me what was doing that noise...is this may be something i would need to replace. ...after the toilet story...this is a walk in the park to do...;)
