Play in steering
My Rinker 250 Fiesta Vee has play in its steering.
Any clues what to check.
thanks
thanks
2003 - 250 FV MerCruiser 5.0 MPI
Best Answer
Michael T
Member Posts: 7,240 ✭✭✭✭✭
I'd call that normal with cable controlled steering. It's smooth and not binding or erratic, right? Just a bit sloppy?
Andy
thanks
With a marker on the rim of the wheel, its about 1 1/4" to 1 1/2". ??
thanks
thanks
The free play is between the wheel and the hydraulic system under the dash, there is no or very little play in the arm to the leg clamp.
Anyone know how to access the connection between the wheel and hydraulics.
thanks
Checked it out again today.
It is a pull/push cable from wheel to stern drive. But also is what looks like a hydraulic assist servo. The cable is connected to this control valve and the valve/cylinder to the arm from the stern drive as I've already mentioned.
The free play appears to be in what looks like a rack (to cable) and pinion coupled to the wheel.
Is there any adjustment between the rack and pinion.
thanks
