underwater lights
mareeniville
Member Posts: 34 ✭✭
I have bought underwater lights for my 2009 260 ec. I need some info on wiring to the switch that says ACC and it goes to the breaker swim lights under the dash. Where is this swim light wire that i can connect these underwater lights. Would the factory aready have ran this wire. Would it be in the engine compartment some where? thank you all for helping me.
Best Answers
freimr Member Posts: 15 ✭✭
Hello
on my 08 330 there was a white connector on the transom just behind the port side engine. The wire is blue/black(24Vdc) and black(0Vdc) connected to the "Swim light" switch
hope this helps
explore7425 Member Posts: 150 ✭✭✭
I put these lights on before and I think you should check to make sure you are using the proper gauge switch and wire. Just ground the black wires together on your bar in your engine compartment and take all the reds to a switch then out of the switch to an inline fuse then back to power source.Bella Sabrina II 370EC -
MarkB
Member Posts: 4,010 ✭✭✭✭✭
Here is the picture I took tonight. Just happened to be at a restaurant close to the marina for mother's day.
I think it's pretty good for a drain plug light.
Now on the underwater lights I have a red and a black wire coming out. What would be the proper way to connect them to this connector . I don't need to put an inline fuse in do I?
explore7425. That pic looks sweet!
I put the LED drain plug light in. It looks pretty nice, not as powerful as what you are showing, but it was pretty easy to install and does the job pretty good.
2019 MTX20 Extreme
