Lenco Trim (30007-001) 123SC switch - pinouts ??
Lenco (30007-001) 123SC double rocker switch.
One of my Trim Tabs is not working which is controlled by a Lenco switch and controller.
To help troubleshoot the problem whether its the switch, controller or actuator.
Anyone know the pinout of the 8 pin connector at the back of the switch to check if the switch is at fault.
thanks
thanks
2003 - 250 FV MerCruiser 5.0 MPI
Post edited by rinkerboy on
Seen the post you mentioned and it turned out I had the same problem with corroded terminals inside the actuator.
