04 fiesta vee 270 shower sump
fredg714fredg714 Member Posts: 2 ✭
replaced the sump box , it only pees out the side of boat , like a check valve went bad . box over fills and leaks into hull, any ideas
  • aero3113aero3113 Member Posts: 9,922 ✭✭✭✭✭
    I would blow some air or use a pipe cleaner to clean the drain line, sounds like you have a clog.
  • fredg714fredg714 Member Posts: 2 ✭
    air will go in and out with ease however the water will not
    I was getting a hydro lock in my shower sump.  If I pulled the pump out of the box and plugged it back in it would start working again.  I was planning to put in a check valve to address it.
    Maybe make sure the drain hose doesn't have any kinks or coils in it or is running up hill?  I know you can't see much of it.
    I would avoid a check valve. That pump will not have the pressure to open it. It will get crudded up and stick too.
    You might go looking for leaks and kinks.
  • rasburyrasbury Member Posts: 8,975 ✭✭✭✭✭
    yes,it should work the way it is installed so finding the problem is for sure the solution!
