stever3232
I have two beeps going off every minute, I checked my fluids and they seam all right any other ideas
    From the FAQ:
    My Mercruiser engine alarm is beeping.  What does it mean?
    If it is a constant-tone alarm, the most common cause is overheating.  For steady beeping, check the outdrive lube reservoir (on top of the engine).  If it is a double-beep once per minute, it could be either the Idle Air Controller (IAC) or a wiring fault.  For a more detailed list of alarms and fault codes, including a formatted copy suitable for printing, look here:
    For a complete list of alarms and faults including detailed troubleshooting guides, buy or download a copy of Mercruiser Service Manual 33 (big block engines) or Mercruiser Service Manual 36 (most other engines).
