250 FV - Lenco Trim Tab Actuator
                    I got a 2003 FV based in UK.
Found the Port Trim Tab Actuator is not working. I have carried out checks of the operation with voltage going through to the actuator.
Anyone know the Model/Part number for the Actuator if they were fitted by Rinker, so I can order a replacement ready for the lift-out and replace it.
thanks
thanks
2003 - 250 FV  MerCruiser 5.0 MPI
While my boat is lifted out for seasonal maintenance, I removed the actuator and stripped it.
Found the spaded crimped terminals corroded to the motor. Cleaned and tested all is now OK with new terminals.
Will do, but I'm in the UK if that's where you want to find one.
