what killed my dang batteries?
rasbury
Member Posts: 8,886 ✭✭✭✭✭
Well, tried to squeeze a few hours boating in today but just was not meant to be-first, changed a flat on my trailer when I went to pick it up- brand new tire with a nail through the side wall so no fixing that one. Then, before we left the storage (right by the river) and I asked my wife, did you grab the boat key/ We all know how that one ended. So, after going back to the house with boat in tow and back to the ramp, in the water and turn the key and nuttin. Both batteries deader than a door nail. So, went below to grab my jumper box and well, that needs a charge as well. Has been 5 weeks since I've even seen the boat. I did have my helm switch and battery switch turned off. I know, I think that my VHF radio works even with everything turned off. When I put the jumper box on the bilge pump came on and thought to myself well I left that on and it was running the battery down after 5 weeks. Further thought however I'm not sure if I heard it start running after I turned everything on (battery and helm switch) or not...Everything I'm sure is still wired as from factory...would that pump run with everything off? Anything else that could be running?? New battereies...
Best Answers
Michael T
Member Posts: 7,241 ✭✭✭✭✭
On my last 3 Rinkers: 2011 226 XL, 2013 EC 310 and 2014 EC 360 at least one bilge pump would run no matter what I did - as long as there was sufficient charge in the batteries.
Hamdog
Member Posts: 247 ✭✭
Ras,
Yes. You cannot disengage the bilge pumps. They are hard wired to the battery. Even with everything off......they will still run.
"Wetted" Bliss 2005 Rinker 342 - Black Hull - Twin Mercruiser 350 Mags - BIII's -
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Mercathode will kill your batteries quickly if in the water and no shore power/battery charging on.Past owner of a 2003 342FV
I was told, they didn't want someone to be asleep in the cabin, batteries turned off at the dock, and have potential fumes from an adjacent boat sneak in without any alarm. I couldn't imagine EVER being on the boat with the batteries in the off position, so I had it rewired.
Have a look above your switch and let us know.
