Water carpet next to galley sink
the carpet is wet next to the galley sink. I think one of the fresh water lines must be leaking. How do I get to the lines without tearing apart everything?
Home port: Hammond Ind.
    Do you have a removable garbage can in the sink top? That's how I got to the sink fitting in a friend's Rinker.  A quick twist with channel lock pliers and done. BTW - to have a look in a restricted space I use a flashlight and a mirror. You probably know you can shine the flashlight right onto the mirror and just change the orientation of the mirror to find the area you want to look at. The light reflecting from the mirror will light up the surrounding area. Takes a bit of practice but works great....my Dad showed me that one years ago.
    I think on some boats if you unscrew and lift off the stove top you can get access from above.
