water in bilge
rasbury
Posts: 8,952 ✭✭✭✭✭
Well, I have jumped on a couple of other threads on this subject and came across what I think is my problem. I am going to assume my problems started when I did more over night at the marina trips. Seems when we did day trips water in the bilge was never an issue. It seems now when the boat is in the water longer, I'm getting more water in it. Thinking it was rain, thinking it was the bellows and generally thinking the worst. I was checking something down below this weekend while at the marina and I finally saw the water running but in spurts. I first thought it was at the strainer for the genny. So I turned the sea valve off and was going to look at it later but noticed water still coming in around that area- when I looked closer, there is a hose that comes from behind the fire wall, it is a Rinker hose.....it is fastened to the floor and terminates towards the lower part of the bilge- not hooked up to anything- and every now and then water starts running out of it and then stops. I'm not sure how much you northern boaters run your air but here in Fl, if it's at the marina it is on the air and it's running pretty much all the time- I am not particularly knowledgeable on the a/c systems, but, is this condensation from the air running? It has to go somewhere just like at your house I would think? It's on the same side as the a/c unit...what do you think?
My AC unit and pan is behind the air return grill in the mid-berth. My pan is accessible. By the way mine is a plastic pan, I think they changed them to plastic after all the issues with the steel ones.
I believe mine already goes to the shower sump. I can't see a hose coming into the bilge, other than he one from my hot water tank pressure relief (we added this, so that if the pressure relief does lift, it won't spray everywhere and especially onto the battery charger. It will basically go via the hose directly into the bilge.
