2 pieces, one on the outdrive, underside of the gimbal unit in the water. Other part on the engine, blue box most likely, front of engine, usually port side.
I found the blue box on the engine and I think I see the unit under the gimbal. Is it bolted underneath where the two sets of hydraulic lines come out and run to the trim pistons? If so, I don't see a wire or any type of electrical connection. Can I just remove the two bolts and pull it down??
Pretty much. There is a wire that runs up from it to the blue controller. These rarely go bad from what I hear. Removing it means taking the drive off and dealing with the wire and keeping water from coming in.
