2000 Feista Vee 330
My port motor beeps when at about 1500 rpms I cut the motor off to eliminate any other issues.
Mechanic says it is the fuel pump and needs to remove the motor to get to it - the pump is located on the port side very tight.
After my research I am seeing there is know sensor on the fuel pump?
Any thoughts or has anybody seen this issue
  • rinker342crrinker342cr Posts: 39
    if its a constant beep it either over heating, water restrictions (clean your strainer) or water in the fuel ive had this happen to me as well and one time was my strainer full of crap then problem fixed... then the beep came back some time later... i exchanged my fuel filters and problem solved
