Little green air indicators on 350 mag mpi horizon
Trashman
I used the little blue pump attached to the engine to pressurize the system. For the life of me i cannot get the left indicator ( two green indicators ) to pop up. Ive hit it with a little wd40 and wiggled it, tapped it ...nothing. Looks like the two air lines from it go to the raw water pump and the ones on the right go down to the bottom where theres a little orange rubber tube that drains when i pressurize. I ran the engine to temp on the muffs then fed the engine antifreeze through the strainer, then pressurized and removed the blue plugs. My first ques is am i ok with what i did or is there water trapped somewhere without that indicator popping up. And Also, I was wondering if this process fills/ winterizes the two heater hoses that run through the hot water heater?
Best Answer
boattech01
you need to make sure the green and white lines going to the sea water pump are connected. there should be 2 blue drain plugs on the sea water pump you can remove to make sure there is no water. if you have a closed cooling system the heater hoses will be filled with antifreeze. if it is not a closed cooling system you will need to blow those lines out.
