Potable water fittings on 250 FV
Does anyone know what brand or type of fittings are on all the Peks tubing on all the potable water lines? I am replacing the water heater and need to purchase the proper fittings for it. Also. I have read that you shouldn't use plastic fittings for hot water heaters, (even though that's what mine had from the factory), so are there brass fittings that are compatible with the plastic Peks system?
Thanks.
Thanks.
