COOL FUEL?
rasbury
Posts: 8,952 ✭✭✭✭✭
I'm looking at the service manual and looking at the fuel routing, it would not appear I have the cool fuel option? I have a 2005 350 MPI motor....my fuel line goes to a fuel water seperator on the left hand side of the motor (looking from the front) and then there is the fuel pump on that same side...looking at the manual, if I had cool fuel then the pump would be on the RH side by the "cool fuel", what the heck is it anyway?
In most cases the thermal sink of the fuel tank volume is enough to not warrant fuel coolers. They can provide a slight boost in power if the fuel temp can be stabilized.
same racers even cool the fuel to low temps below ambiant even to extract more power
Ras,
I am attaching a link to a site showing Merc engine parts by categories. The page I am linking to is the page where you will need to choose your engine serial number. Click on your engine serial number range and you can look through all your engine parts. There have been some service bulletins regarding cool fuel on the 350 Mags. Also realize that if your serial number is close to a switch check the range above or below as there may be some carry over. I think that is the case on some of the pre-fuel separator filter you were inquiring about on another thread.
http://www.mercruiserparts.com/selectSerailRange.asp?doc_nbr=350+MAG+MPI+ALPHA/BRAVO
I also use this site for my B3 drive.
Rob
there are EFI systems (namely first and second gen mopar) that don't utilize a return, but that isn't the best way to do it...
I guess it depends what you consider "big" power (drag racers super cool their fuel, its not ambiant cooled) Its not the same thing.
and I was referring to super cool.. ambient ain't helping much. which is why the notion of a 'cool fuel' on the mercs is something I ain't buying...
