possible leak due to old windshield gasket?
After a lot of rain, I get water on the carpet under the starboard v birth cushion. Seems to run down behind the viny and seep under the carpet. I'm not sure if it's a rub rail issue or the windshield gasket which seems to have shrunk by about 2 inches. after a particularly bad storm, even the cabin floor was damp by the bathroom door. Anyone experience similar leaks? Need some recomendations before removing rub rail (I hear it's a real pain). 2003 270 FV
Thanks
    I was getting water under cushion in v birth seemed as if it may have been leaking from the port window which was under base for my grab rails , to find out where the water was coming from I used hose and soaked around window for a few minutes,started with window because it was lower than rub rail I pulled a bit of vinyl under cushion up an stuffed some paper towel there nothing got wet ,so I moved up to rub rail,still nothing,next I wet around base of grab rail ,that's when I started to notice paper towels getting wet.
    2002 Rinker FV 342
  • DazeOffDazeOff Member Posts: 164 ✭✭✭
    Thanks for the info bv. I'm almost hoping I can work my way with the hose all the way up to the windshield gasket since that would probably be the easiest fix.
    Thx again.
    Also look for missing screws or screws that are nor fully seated and ones not caulked. On many Rinkers there is a plastic insert on the side of the windshield frame that will expose the screws so you can look at them. As well, there should be a drain port at the lower end (stern end) of the windshield frame and often the hull below that drain has a dedicated drain dip or slot tooled right into the fiberglass. It might be a relatively simple process. A couple of loose screws or a missing screw combined with poor drainage can put a surprising amount of water into your cabin. If there is nothing obvious from a visual inspection bella-vita's idea of using a hose starting at the highest point and SLOWLY working your way down is a great idea. Remember too that water can run along the inside of the hull and appear downstream. Do you have one of those construction-type tiny inspection cameras with a small lens at the of a flexible cable. Those are great for looking behind cabinets. that's how I found the cabin leak on my 360. It was coming from the port side windshield.
  • aero3113aero3113 Member Posts: 9,347 ✭✭✭✭✭
    I was able to remove the foam seal to expose the screws for my windshield. Once removed, I sealed each screw one at a time. Hopefully next season I won't see a stain on my headliner! I was also able to remove each screw for my bow rail and reseal them.
