i need help to finish this tv stuff
rasbury
Member Posts: 8,242 ✭✭✭✭✭
So I started another thread. So, to recap,I have a 2005 270, it has the factory Genny' it has shore power. Being an 05, the TV is an 04 and is not digital. So, as others have concluded' new TV in order. I seem to have a little different set up on my antenna so the new thread.
The antenna that came with it, well it did not survive right off the bat. I had other issues to deal with more important but this one is getting to be on the list.
Mine also looks like it came factory with some sort of amp for the radio. The electronic box by the TV that others have described is a little different. First, on the outlets' I have two. One says to tv, the other to pure amp. So, the antenna on the arch is for both the radio and the TV? Also, on that power box, it also has a switch for a/c and d/c...is that the normal set up? Is there a difference in the antennas if it just does the TV vs both?
Best Answers
Optionsbella-vita Member Posts: 411 ✭✭✭I think ac/dc is only to power the ant (it's a power ant it needs power from ac/or dc when not connected to shore power or not using genny)only so if u have a dc tv u can use ant on the hook with batt power.mine seems as if it is only wired to ac it does nothing when I switch to dc no tv channels no red light comes on when switched to dc.2002 Rinker FV 342
OptionsBellevilleMXZ Member Posts: 732 ✭✭✭I think from what I remember a lot of the ant. come with the splitter/amp anyway? I was looking at a new one as I mistakenly thought I needed a new one for digital tv. Most came with it as a kit.2005 Rinker 270 FV Volvo Penta 5.7Gi
OptionsHandymans342 Member Posts: 10,375 ✭✭✭✭✭Its not the normal metal spliter thats on cable today, Ras
