filters
rasbury
Member Posts: 8,925 ✭✭✭✭✭
I want to service my 5ke filters. I did the plugs, replaced the zinc (everyone need to check theirs, I was shocked to find it gone with only 100 hours on it.) I have a sierra fuel water separator so no big deal there. I traced the fuel line to the Genny and there appears to be something else going into it. It has more the shape of a regulator but assume it must be another filter as fuel is not pumped into it and I'm sure has its own fuel pump, correct? Where can you get that filter? The marine max folds said they can order about anything...
First of all a number that I have used for good info from Kohler is 1-800-544-2444. There is also a website at KohlerPower.com/marine
Question: Is your generator the 5EKD? .....If so, regarding fuel it should have.... a fuel filter + a fuel pump/cooler + a fuel pump + a fuel inlet+ a filter screen in that order.
Full Generator Kit - GM77091
Backfire Flame Arrestor - GM24212
Fuel Filter - 267987
Fuse (10 amp) GM42337
Fuse (25 amp voltage regulator) GM42339
use (20 amp CO sensor fuel pump, O2 sensor and coils) GM47427
Fuse (10amp controller) GM42337
Fuse (10amp auxiliary winding) 358337
Oil Filter 52-050-02-S
Seawater pump Impeller Kit 359978
Seawater Pump Belt GM53040
Spark Plug 25-132-16-S
Zinc Anode 260085
Brushes(2) 239282
Container 344835
Wow, I will have to check into model etc. I don't recall seeing any belts looking your list over quick-I think its just a 5e. Anyway, boat is put up for a bit, will work on some other bugs for now...like the tv.
thanks for the info
