Led cup holder upgrade
Trashman
Member Posts: 432 ✭✭✭
I ordered these from eBay. They are a perfect fit. Green led with a stainless steel bezel. Just wiggled out the old original holders and peeled the caulk off. Placed a new bead of caulk around the hole and pressed in. They have drain hole fittings in the center that has a drain tube that runs to the bilge . The old tubing was a different diameter so I had to replace. Each holder has a delicate wire that is held to the side with a rubber band. Before I started I smeared some marine caulk along the wire to hold in place, I predict that band would soon fail. Connected all the wires together with the heat shrink type connectors and tapped into the courtesy light.
Thanks!
That’s real cool nice job
