Battery question
rasburyrasbury Member Posts: 9,012 ✭✭✭✭✭
I brought my boat home from storage last night and when I turned the battery switch on, the lights would not come on until I put it on both batteries. I had the batteries off and the helm switch on, as far as I know, nothing running. It had has sat for around 6 weeks. One time I put it up and apparently left the bilge switch on and I'm sure that is set up to run no matter what. Is this what you would say normal? Also, lights would not come on because either battery had to low power and together they would work?
Best Answers
    Did you call Walmart to see whats wrong LOL
  • rasburyrasbury Member Posts: 9,012 ✭✭✭✭✭
    Walmart?
    Yep things like the bilge pump, radio presets, and sometimes clock at the helm drain the battery even when the switch is in off.  Ask me how I know....
    Thanks Mark...guess I should have prefaced my storing, its usually no more than a couple weeks between outings year round...except around the holidays but that is not off limits. At any rate, I got in the boat this am and tries it again....same result but I also turned the ignition on, heard the fuel pump, bumped the starter very lightly..and it fired so I must have something stupid going on..helm switch is on, fridge runs...weird!
    In combined it's taking power from the crank battery.
    I think your house battery is shot. Needs more investigation but that's my gut feeling.
    I plugged in and turned on the battery charger, both batteries around a year old so I hope not- we'll see what happens!
