Bravo 3 Service Recommendations
Just pulled the Bravo 3 from our 2000 Rinker 232 Cuddy Cabin with a 7.4L. The reason I pulled the drive was I noticed one of my engine mounts were loose, so I am checking drive shaft alignment. When we purchased the boat 2 years ago the shop pulled the outdrive, pressure tested it, and replaced the gimbal bearing. Any recommendations on what I should service while I'm in there? The bellows look good, and I'll make sure the gimbal bearing is smooth, should I do anything else? Thanks in advance.
    edited February 2016
    IMO check cables and seals as well as the wires that comprise the Mercathode system.
  • craigswardmtbcraigswardmtb Posts: 1,015 ✭✭✭
    Replace all seals and orings.  Check the water pickup hose as it's known for getting gunked up and degrading over time. And lube the drive shaft/coupler and all cables.
    If I had the drive off, I would replace the bellows and the shift boot. They might look good, but could fail, then you are pulling the drive again.
  • jme097jme097 Posts: 1,224 ✭✭✭
    How hard is pulling the drive on your own? I have the outdrive service done every fall to inspect and change the lube. Just curious as to how hard it is to your own
    Boat Name: Knot A Worry
    Takes 2 people
    B lll is pretty heavy, in 2014 my tech removed both by himself. I was worried that he might strip the bolt lugs so for 2015 I insisted he use the shop's engine dolly.  Afterward he agreed that WAS the way to do it.
    I do it myself with a drive stand that I made out of wood and casters from Home Depot. It's not to bad. Off is easy, on takes a bit more elbow grease.
    ....... and you have to line a few things up like the pilot tube etc.
  • LaReaLaRea Posts: 8,069 mod
    While the drive is off, check the water pickup hose where it connects to the transom.  The fitting can get corroded and restrict water flow -- especially on salt-water boats.
