what do I use?
rasbury
Member Posts: 8,872 ✭✭✭✭✭
I have another thread on touching up my outdrive, the grounding wire that goes to the upper part of the out drive I broke off the bolt that secures it. So, I will drill and tap a new hole for it. I have two questions, first there has to be something to isolate the stainless steel from the aluminum for corrosion. The other question, it did not appear there was a bare surface there for contact to the drive for the wire loop and the head of the bolt to make contact, should there be?
Best Answers
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
No, the wire loop touches the screw and the screw threads touch the metal housing -
aero3113
Member Posts: 9,681 ✭✭✭✭✭
Can you drill out the stainless screw that broke and use an EZ out instead of drilling a new hole? Or drill out the stainless screw all together and then tap to the next size up?2008 330EC -
raybo3
Administrator Posts: 5,592 admin
Try a left handed drill bit. Works great.....2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
