what do I use?
rasburyrasbury Member Posts: 8,897 ✭✭✭✭✭
I posted this question in the wrong category... had two questions: the grounding wire to the out drive I broke off the head of the bolt trying to get it out as I needed to re paint that area. I will drill and tap a new hole. What do I use to isolate the stainless steel and the aluminum? Also, there was not a bare spot for the wire loop of the ground and the head of the bolt to come into contact with the metal of the outdrive, should there be?
Best Answers
