sanity check.... engine upgrade
so I need some items for my 'lil 212...
exhaust manifolds and risers are due... circulation pump is due... I have no clue about compression on that engine, but it appears all of the above is OE and a build date of '05... If I'm going to pull it, I'd do a four barrel intake w/ 650cfm holley, 1.6:1 rocker rollers, water pump (as said prior) double roller timing chain, obviously plugs and wires, likely new oil pan, likely new oil pump, ect... y'all know how these things go...
If I do all of these things, and I do them all myself that way I know they're done right, I'm looking at a cost of around $2.5k~$3k...
I can buy a 383cid engine right now for $2500... it lacks accessories and it lacks intake manifold and carb... it has merc exhaust manifolds and risers, dizzy, cap, wires, plugs, water pump, roller double chain, 1.5:1 rocker rollers, fuel pump, ignition...
I'm almost certain my current accessories will bolt right up...
The tq and hp curve is off idle to 5500 RPM (370hp@5500rpm, but 320@4800rpm, if the graphs are accurate and the builder is providing accurate dyno charts, it's showing 310@4400rpm)... it's rated to 6200rpm w/ the rollers and the beehives... for comparison, my 'lil current 262 only produces a little over 160@4400 rpm, but jumps to 190@4800... apples to as close to apples as can be made, I'm looking at adding just a bit under double the HP/TQ at 4400rpm.
I have an alpha drive... it isn't rated to no 6200rpm.. .As far as me operating the boat, I don't need the speed or power at anything above 4k RPM right now- and rarely go there, so I don't think I'd be taxing the alpha that bad... I like to get on plane and back down to ~20-25mph, or just over 3k rpm right now w/ the Ron Hill Pleasure 5 19p/14.25" prop... I don't think I'll be changing that (the prop), but I may... I don't foresee my uses changing anytime soon, but, again- y'all know how those things happen... I like the idea of having more 'get you out of trouble' power (power in terms of agility and reaction, not necessarily top speed)... If I do re-prop at the same time, this rig ought to be able to turn a 23p, if my guts are right... and it may make more sense to do that.
which would you fellers rec- a repower or a refresh?
But ****, if you can get a big power jump for the same cost and not that much more work then why not. If its a direct swap/
they can be tweaked... but it's still an alpha...
a lot of the concern can be mitigated by how the user uses it- and I just ain't into hauling **** and scaring small children and dolphins....
those things are witchcraft and voodoo...
BTW..... is there such a thing as sanity where boats are concerned and more importantly where boats and HP are concerned? I could never stay sane regarding those discussions. Fortunately for me I had Admirals who understood! LOL
So... The 383 may be back up for consideration... I'm looking at a thru hull exhaust that will eliminate the issue about heat in the drive introduced by the exhaust. Still, concerned about grenading the box- but if it makes it a season I may consider drilling the two extra holes for a bravo.
So.. I've got some contimplating to do...
Man, I didn't set out to drop ten g's, but it's getting there quick..
I appreciate your advice, sir...
I don't need a speedboat, but I like enough power to get me out of trouble if I'm dumb enough to get into it... I'm thinking range this season, with fuel being cheaper and re-powering to a more reliable plant... I'm thinking a 383 (this one built off a 350SBC) will be actually easier on fuel than the 4.3 under similar on-board weight...
if i'm ever up there in the winter and have the time, I'd love to give that a shot...
