Snubber
chamberb
Member Posts: 265 ✭✭✭
First time mooring question. I have a 260 EC that I will be keeping in a slip for the first time. The marina requires snubbers, which I have never used. Online research shows I should be using 7/16" snubbers, I just thought I would check with the folks here on the forum for any recommendations on brand/type/size.
Thanks!
06 Rinker 270
That's the reasoning I guess, to protect their equipment...
Thanks Mark, I will reach out to them. I was just reading their Lease agreement and it requires them, I have never had a boat this size or a slip before , so it is all new to me. I searched this forum for snubber information before I made this post, it looks like I should put one on my anchor line too, to protect my windlass?
2004 Cruisers Yachts 320 W/6.2L I/B's
Boat Name- Anchor Management, Mayo MD
Unless you have an all chain anchor rode (which in itself would act like a snubber) a prusik knot is the way to go, putting on a snubber with a rope rode would be a major PITA
Youtube search for "prusik knot" is underway... :~)
Thanks Dream-Inn and DD2!
Thanks MT!!... I was starting to worry about you, I posted that hours ago :~)
Never even heard of a "snubber" until now. Yet another cool thing to buy this year.
I just looked up the "Prusik knot" and can't figure out what you would do with that in relation to an anchor. ???
-=Mike G.
2014 Rinker 260EC
They do look a good idea for your cleats though!!
In short: the prusik knot can be made by wrapping a length of mooring line around your anchor rode so that when pulled against by the rode it tightens but when pulled by you it releases.
You use the two ends of the mooring line to tie -off on your forward bow cleats then back your rode thereby taking the load off your windlass but more important your SS pulpit thereby preventing it from being bent. Simple to do.
So leave both ends of the mooring line free, so each end can be tied to a separate cleat? **** winter.... I wish it was time to unwrap the boat so I could try this out, I do better when I can see it and try it...
Prusik is a line to line self tightening not... I used them for years as ascendor knots.
For 'shock' protection of a line, daisy chain it. Make an overhand loop about three inches using 5/8 line, and pull another loop through it without pulling the running end through.. do this at least six times for what ends up looking like a chain of sorts. Once you've got enough 'spring' for the task, pull your last loop through but this time pull the running end all the way through, and make it an overhand knot... Boom.. a line that springs.
