Gas tank gauge
MarkB
Member Posts: 4,009 ✭✭✭✭✭
I recently had a mercruiser smart gauge installed on my boat. I got the boat back yesterday and have found my gas tank level gauge is to reading at all. The level shows on the digital display of the smart gauge. It looks like the mechanic severed the connection to the older gauge. Is there any reason the two cant be off yea same sending unit? I'd like to have the gauge working
Sorry there's a typo in my original post, for some reason I can't edit.
Anyhow, my Faria gauge is not reading tank level at all. The mechanic had to put on a special harness on the fuel sending unit to get the smart gauge to pick up level. I can see the old harness is disconnected, so I'm guessing this severed the comms to the Faria gauge. Can the live/neutral be spliced to the Faria gauge so I get readings on both the Faria and Mercruiser Smart gauges? Or will this mess the one up with the other?
From what you write Raybo perhaps yes it is a problem, not sure. I don't think they changed the fuel sending unit, so the output should still be standard for both gauges. I'm guessing if the output is the same, the resistance at the gauge would be the same. Anyhow, now I am clearly starting to guess...
2019 MTX20 Extreme
OK. Dug into this a little. Fuel sending units control the amount of current going to the gauge. Looks like standard resistance specs are 33 ohms to 240 ohms. Now for a dual station setup, the fuel sending unit gets changed out to one with half the resistance ie. 16 to 120 ohms. This provides twice the current to drive 2 gauges. In your case, we're talking about one gauge and one digital readout. I'll see if I can figure out how the Smart Gauge stuff works and get back to you. The key is to figure out how much current the Smart Gauge is using.
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
