Lenco control box
Can anyone direct me to the location of the Lenco trim tap control box on a 2004 FV 312? The wiring behind the helm appears to be quite a birds nest and I would like to disturb it as little as possible.
Brian
Brian
Best Answers
tangocharlie
Member Posts: 6 ✭
I have the exact same boat. This year I am missing lights on the starboard side of the keypad but the trim tab still operates normally. I suspect it is either the "black box" or the key pad itself. Looking at the install instructions the box should be close to the keypad in the dash. I have not had the fuse panel off below the throttles but this looks like a good place to start. I know what you mean about a rats nest, it doesn't look things are wire tied very neat like my previous cruiser. I'm going to look for mine this weekend, if I find it I will let you know.
Michael T
Member Posts: 7,241 ✭✭✭✭✭
Also look at the contacts and pcb on that lit key pad as there might just be some crud on it that you can remove and spray with some pcb lubricant.
