Temperature at which a block will crack
aero3113
Member Posts: 9,566 ✭✭✭✭✭
Im just wondering how cold and for how long it has to be to crack a block. I ran my boat the other day so no more antifreeze in it. Now the early mornings are getting below freezing. Last night I ran it and figured it will stay warm to prevent freezing. This week is supposed to be warmer.
http://ultramarineperformance.com/engine-pinning/
06 Rinker 270
I've seen the certified ceramic heaters used which are made for boating and they are fine. Not that I have a desire to use them, but they are made for the application. I've seen many of those pictures (heck, I've had a fire on my boat) and I have to say people really do some dumb stuff.
the better plan is to use anti-freeze that has an anti-corrosive component, even if you have to add it, no?
autos run closed cooling systems and the anti freeze has a component that creates a 'skin' on hard parts, which protect them from internal corrosion. us running raw systems don't get to enjoy that. that doesn't mean you can't store over the winter with something that does, though... just don't use standard auto coolant/anti-freeze... one drop of that stuff in the pond can contaminate it terribly.
keep an eye on corn glycol... it foots the bill boaters need for antifreeze in a storage below freezing circumstance, it is absolutely safe to the environment, and it provides anti-corrosive properties to boot.
that is what will be in my floater next winter for sure.
that will not work out so well in storage if all the juice is gone- corrosion happens on a system when all the fluid is missing... I've seen water pumps seize, and interior of exhaust manifold spit out pure red water when the engine is first fired...
which is the long answer to say- you can drain it ALL, and blow it out, and that will most likely be all you need to do to protect your engine over the winter- but filling it with proper percentage of antifreeze will reduce corrosion, and using antifreeze that has corrosion inhibitors is an even better solution...
if I didn't run in saltwater i don't think i'd concern about this that much- but that salt is an excellent at doing really bad things to metals... thorough fresh flush and total blowing out is absolute minimum- the best being that + antifreeze and corrosion inhibitor of some type that won't pollute when you launch in the spring.
