Help, can't figure fuel gage issue
DanD2
Member Posts: 847 ✭✭✭
I've posted this in the Cruiser Forum also....I've got a 2005 Fiesta Vee 342
Port fuel level gage was acting funny last year and towards the end of the season, it stopped working. I replaced the sending unit and it still does not work......here's what I've done to trouble shoot
Hooked up sending unit to Stbd side and it works, Swapped gages, Port gage works on Stbd side, Stbd gag does not work on Port side, I also swapped plugs on the back of the gage.
I'm befundled.....lol. What am I missing here??? Can anyone help me out?
Are you saying to ground a wire and then touch the appropriate pin and see if the gage moves?
I didn't think about you having the gauge cluster, 2 engines duh! Electrical issues s**k!
Do you have a good ground wire connector attached to one of the screws on the cover of the port sending unit. That is the only way for the sending unit to work correctly. Did the grounding wire break?
Thanx for all your help and comments
